Will the struts off of a 1996 Camry, fit my 1996 ES300? What parts are compatible between the 2 cars? Thanks peeps
Probably. The best way to find out is to get the Toyota part number for each. You can also call any auto parts store and see if the replacement parts are the same.
If you're going to be doing any amount of repair work yourself, you definitely need a manual like Haynes or Chilton for your car. It's about $20 and worth its weight in gold.
