tail warning light on the dash
Old 01-25-12, 10:42 PM
pitachip
pitachip's Avatar
Unhappy tail warning light on the dash
I have a 1998 es300 and I am having problem with tail warning light on my dash.
The yellow warning light came on today and checked tail light. The right rear parking light wasn't working, so I replaced it but still the warning light is on. I checked all the lights and they are all working fine. Can anyone help me with this warning light off from my dash board??
Old 01-26-12, 02:54 AM
marcoes300
marcoes300's Avatar
it can be only because its not connected as its suppoise too or not the same bulb as the factory one ... mine have the same probleme but everything work so ....
you can look on the forum ,there's many post about it that you can read about but if i remember , not alot ou ppl have slove this problem.
Marc
Old 01-26-12, 08:22 PM
pitachip
pitachip's Avatar
Marc
Thank you, I will look it up.
Old 01-27-12, 02:19 PM
Hayk
Hayk's Avatar
I had an issue where everything was working but I still had a warning light. It turned out that some bulbs were just old and not bright enough. Try switching all your brake lights with new ones. Also try to see if there is a certain condition when you get the warning. Is it always on, or only when you turn your lights on? Or does it only appear when you use the brakes?
Old 01-28-12, 10:01 PM
pitachip
pitachip's Avatar
it comes on when i turn the parking lights on,
I fixed problem. had to replace with 2825LL which is 5watt bulb.
thank you everyone for help.
Old 03-28-14, 06:46 PM
hilllexus
hilllexus's Avatar
Worked for me too. Thank you!
Mitch51
09-27-16 04:56 PM
G_ride
12-27-10 12:32 PM
mooseboy84
12-15-07 05:27 AM
NAZTY97
SC- 1st Gen (1992-2000)
14
02-23-03 10:31 AM
Quick Reply: tail warning light on the dash
