Side power mirrors stopped working
Both side mirrors won't adjust. I checked the CIG fuse and it is fine and the cigarette lighter works. I also checked a few other fuses and did not find any problems. I also tried the suggestion of testing to see if the mirror would move with the seat memory and it did not.
I checked the continuity on the switch and it checks out okay. I checked the wiring harness going to the switch to see if I could get a voltage reading (with the key in the on position) and I did not. I was not sure which pin was suppose to be the power but none of them reported a voltage reading. One thing I did notice was that pins 5 and 6 on the harness both went to ground. I am not sure if this is expected as I have never tested it when it was working.
Any suggestions would be appreciated.
