1995 bulb specs
1995 bulb specs
Hi, new to the site as of tonight so sorry if there's already a forum on this!
I'm replacing some of the interior bulbs in my 95 ES and need the bulb type of the driver/ passenger door and the front/ rear overhead lights. Also wondering why neither of the lights come on when the door is opened (happened before the front burned out, and yes the rear switch is on "door").
please disregard any "noobishness" about this post, lol
It could possibly be the reason, you should check all the fuses to make sure none are blown.
For those lights just check the ones next to the steering wheel and the ones in the bonnet.
If a fuse is blown, easily just replace it with another one of the same, if a fuse isn't blown you have a little bit more of a problem :P
