Timing Belt question/ ES300
When I did my timing, I also changed the water pump, cam seals, crank front seal, all idlers, valve cover gaskets, thermostat, coolant, etc..etc....took me about +10 hours. However, I was working a few hours here and there. And I took my time applying the right torque, and applying anti-seize / loctite on fasteners.
If you are doing just the timing belt, I would say 3 hours.....
Thanks for the reply - when you did the timing belt work, was there any problem areas to be on the watch for - such as working through the wheel well to get to the lower area?
I have a 97 ES300 and some of the fasteners haven't been removed since from factory. As a precaution, I sprayed WD40 and let them soaked for a while before putting a wrench/ratchet on them.
I agree with PlatES300. The bolts holding the cam sprockets took a while. But if you are not replacing the cam seals, you don't have to worry about it.
mooseboy84
10-31-15 11:35 PM
