Snapped valve cover gasket bolt. Ideas?
My valve cover gasket bolts were VERY loose. Like not even finger tight loose. So I very gently tightened them and one of them snapped. Any ideas guys and gals? TIA.
Edit - its the one that's front and near center by the exhaust manifold. I can see the bottom of the snapped bolt on the underside but not enough to get pliers around it.
Thanks ASG14, that's a good idea. The gasket was leaking a little so I thought I'd tighten them. I am so shocked at how loose they were. Seriously, I could start tightening them with my fingers. That can't be normal. I've read the torque spec is 6ft/lbs, is that correct?
69 in/lbs to be exact in manual for my '96. I THINK yours is the same even though it's the VVT-i version of the motor. I personally use a torque wrench. 1st time I did it I had to call a couple friends because I thought being that low was a mistake, lol.I think at this poitn though, you may want to repalce the gasket itself. you also need to put some RTV (silicone sealant) on a few spots when you take the valve cover off.
Cool, thanks for the good tips. I was going to take it off later this summer anyway to inspect for sludge. Who makes the OEM gasket? Is it Beck/Arnley?
Personally, for THESE I go OEM. I've used a couple aftermarket valve cover gaskets and they didn't sit as flush as the OEM ones. There are dealers online that sell them discounted, I think one is a sponsor here. For the RTV (Silicone), I liek to use Toyota FIPG (part # 00295-00103). It;s around $13.
For most of the T-Belt/Water Pump related stuff I use Aftermarket quality parts like Aisin (OEM Toyota company). I just always have a thing with seals/gaskets, I liek to use OEM for those.
When puttin new gaskets on:
Put FIPG at any joint or corner the gasket goes after cleaning the old stuff off. Ex: the cam hump by the cam sprocket. You'll see where they put the grey RTV from the factory - put it there
When tightening the bolts down, go around 3 times with the torque spec. The gasket will compress and the bolt will be loose.
Ishino makes the valve cover gaskets for these cars.
Thanks everyone. On a side note, why is torque spec so low? You would think it would be a little higher, especially given to how often the valve covers start leaking. What was Toyota thinking?
Rokas
36
12-15-20 12:01 PM
Bankswood
Performance & Maintenance
12-09-14 10:46 AM
