Amp Under The Passenger
Whats up guys
I was planning on taking out the amp under the passenger seat and put in a 4 channel on there or just upgrade the 2 channel amp, can i use the wires there already or would u suggest not doin that, i just need a little more boost with little less effort than re-wiring the whole car and slapping the amp in the trunk
this is what i have in my car. the amp under the seat is 4 channel, which allows front to back fading, with left and right balance... the factory radio head unit is not wired to run directly with another amp, so you will in fact have to leave the old amp in there and use it to take the signal from the radio.... I can't wait until I get a new head unit. Joe knows as well. His is the same as mine.
Chicago Lexus Club Moderator
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
I have 2 two channel amps and 1 one channel amp. I think that you should change and run all new wires to the amp.. Very good idea, and you will get a lot more power. You might wan to put it in the trunk though. It might get a little hotter then the old amp, and wont get scratched or anything.. Just a suggestion.
Adam " Lexist "
Adam " Lexist "
