Fog light installation on 95
Do you need the fog light housings? Or the bulbs? Or both?
Do you want Projectors: http://bit.ly/zl06A8
Or...
Reflectors (this is my personal vehicle): http://bit.ly/A5QJV8
I bought my assemblies on eBay, for projectors you want these (Yes they work for 95's): http://bit.ly/yltp4W
Unfortunately, I cannot find Reflectors on eBay anywhere. But you could find them in salvage yards or other sites.
Bulbs, you want H3 halogen bulbs. I'm using the H3 Putco "Jet Yellow" (item #: 230003JY) bulbs in the picture above: http://www.kbcarstuff.com/Putco-Jet-...lbs-p/23jy.htm
Installation is easy, three screws for each assembly, connect the cables, and to put in bulbs you simply unscrew the back end and pull it out. Everything else is straight forward.
Or...
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
However, this might help a bit:
http://www.lexussouthatlantaparts.co...ey_trimLevel=0
Also, salvage yards would be good!
Just a quick question seems I may do this in the future,
How do you turn them on if they aren't there originally? On my ES it doesn't have a switch for them or anything (obviously) so if you were to put them in aftermarket, would you have to do your own button/switch or is there some other way of doing it.
How do you turn them on if they aren't there originally? On my ES it doesn't have a switch for them or anything (obviously) so if you were to put them in aftermarket, would you have to do your own button/switch or is there some other way of doing it.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
AHA!!!!!!!!! After a few days of watching eBay, I HAVE FOUND THEM!
And get this, they are in FLORIDA.
http://www.ebay.com/itm/1994-1995-19...#ht_500wt_1203
Swoop on those quick! That is super cheap. I payed $60 for each assembly individually.
Also, while you're on eBay, grab the putco jet yellow's: http://www.ebay.com/itm/H3-Type-Halo...6#ht_500wt_970
