Need timing belt advice
I just bought a used 2004 ES-330 with 91,000 on it, driven by older, slower driving folks. I'm sure the car was never, ever "pushed."
I've not dying to put in a new timing belt that was due at 90,000 miles. I'd like some feedback on this thought: I am assuming that the V6 engine on the car is "non-interference", meaning that a broken timing belt won't wreck the engine. If it did break, I think I'd be paying for "re-timing" in addition the new belt. I have two other cars and towing insurance and not worried whatsoever about needing a 100% guarantee that the car will always be available to me. So I'm thinking about waiting on the T-belt and water pump until maybe 130,000 miles or so. Am I just crazy to think about doing this?
I just have confidence in Toyota that the belt will last quite a bit longer. I'm not seeing any comments on this Forum about people crying about belts breaking in half at 95,000 miles. It seems Toyota has built in a pretty good "fudge" factor here.
But my opinion is strictly tentative and awaiting moderation by more experienced owners! Thanks for any comments!
best thing to do, just pop the timing belt cover off on a weekend or something and inspect the belt.
if you can see any cracks where it's bending around the cam gears.....start ordering your parts.
if it's got no cracks, then just keep driving it. maybe apply some belt dressing while ur at it
Although this engine is indeed a non interference engine, it can still get severely damaged if the timing belt breaks. One such scenario would be if you have carbon built-up on the top of the pistons, or valves. Because of the very small clearence between those two components, such a layer of carbon, can still cause them to crash into each other and cause major damage.
Having said that, the chances of such an event occuring, are rather remote, but not non-exsistant. In any case, at that milage, your timing belt should still be good.
Phil
Phil
The engine is interference by everything I've read because of the variable valve timing. Stick to the recommended replacement schedule unless you like to risk destroying the engine.
Check the website below to determine the interference status of any car
http://www.gates.com/part_locator/in...cation_id=3598
Phil
That Gates list contains quite a few errors FYI. But I'm not going to argue this it has been discussed at length before.
Honestly, read this thread: https://www.clublexus.com/forums/es3...us-at-50k.html
If it were me, i'd do it. Spend the 350$ for parts from www.rockauto.com, pay the 700$ in labor and be done with it.
I just got one of the OEM spec kits for my dad's RX330 which was at the interval to swap it over. And months before my buddy's GTI only had 140k km's on it and the belt snapped - new head required.
Your call.
Your call.
Im at 180k miles right now on my 1995ES. Purchased the car with 100k and i have service records that show that the belt and all related parts were replaced at 65,000. Not sure why it was done so early, but nonetheless, i am debating whether or not to have the belt replaced which im told will cost at least $1000, or to continue driving her until the belt snaps and then ill pronounce her dead.
On one hand i know if i change the belt i can get many more miles out of her, but on the other hand, im prepared to buy a new car and not put $1000 into a $2000 car...
decisions...
decisions...
decisions...
decisions...
my belt was changes at 93k KM (not miles) by previous owner. i am at 191k Km. now the belts go for 140-150,000 km is what my mechanic says so i should be good alteast until 200k km.
but! i really want to pop it opena nd take a look so I can sleep easy... you mentioned belt dressing..does that help like alot?
so if i pop the cover on a saturday and spray it all over would it help the belt "stay in shape" a bit more..?
thanks alot, appreciate all your current (and previous help) !
decisions...
decisions...
I have heard of some freak occurences with non-interference engines and timing belts breaking, but the odds are slim. On a car that's only worth $2000, I'd just drive it until the timing belt breaks and then figure out what you want to do. I've heard plenty of people get WELL over the suggested interval, I could easily see it going for another year or two without an issue.
BTW, you should be able to find an independent shop that can change just the timing belt for under $300. The $1000 quote is probably a Lexus dealer that also replaces the water pump and a few other parts along while swapping out the timing belt.
