the best shock setup comparable to avs?
hey guys, I still havent made a decision on the suspension. It seems that I have one leaking strut and i can get by on changing the damping for now. So im thinkin i could save change one avs strut at a time. But for the price of one avs strut, is there a aftermarket setup that is VERY comparable/competitive to the avs? what comes close? i miss the feeling of "hovering" over cracks and potholes.
also anyone hear about strutmasters on a 97es 300?
thanks
thanks
....ok....i know you guys have some fancy set up and are fed up with the same topic. Im thinking about going monroe oespectrum. They have a 90 day garantee if your not satisfied. comments?
Any new struts will 'hover' they get lower with time and abuse.
I don't have AVS - thank god. Such stupid system. They just get harder or softer, where a normal strut is the 'inbetween setting' at all times.
FWIW, get normal struts that aren't crazy expensive, and call it a day. Can't go wrong with quickstruts by Monroe. More money - yes, but less time spent labor wise and its all in one and not mixing old components like strut mounts. Works out best in the end for an OEM-like ride, with lifetime warranty.
Cheapest to get them on rockauto.com, and rebates galore. Might as well look into other options if you choose just struts & mounts [highly recommend to change 'while you in there']...
I'm still on the fence if I want to go the cheap Monroe route and then having to redo it later. I am more of a "do it right the first time" kind of guy, even if it means spending double the money.
The general consensus seems to be using KYB struts with Toyota strut mounts. As for other components, like spring insulators, boots, bump stops, it doesn't really matter.
Thank you for the comments that everyone sent. Considering the many threads topics on shocks and ride quaility, there are tons of combinations and "tastes" that different people prefer. Im learning Its is just as personal as choosing shoes. With that said, this thread is just another bunch of opinons, and basically just a way to make some conversation about shocks.
I have been spoiled by the AVS system, so maybe when its really time for full i want a a setup that can come close.
Mr.booby i feel ya.
The strutmasters might be worth the envestment vs $400+ for a shock.
BTW, would you all say that the light metal on metal grinding sound when slight shimming over a minor bump is the mounts?
Mr.booby i feel ya.
GSspeed
45
05-20-20 08:34 PM
