MAF sensor question
hi, guys. i have a 2000 es300. 84K miles and never had any real problem with it (except when i put on some dang falken ziex tires - but enough about that). day before yesterday, hubby said check engine light came on and when i went to look, there was both the check engine and the TRAC OFF lights on. i turned off the ignition and the car sort of "sputtered" (?) and the battery light came on momentarily then the engine turned off.
i was alarmed and restarted the engine which seemed to have some issues but did turn on. subsequent turns on/off were fine.
yesterday, i took it to the mechanic and he said a battery cable was loose. he also said i needed a new MAF sensor and forgot about the TRAC OFF light but when i mentioned it, he put the car up on a lift and said it might have been a fluke when the check engine light came on because of the sensor.
i got the check lights turned off and things have been driving ok. but i think it's going through gas like crazy but i don't know if that's just my imagination.
so my questions are:
1) could i have gotten the MAF sensor error code because the loose battery triggered a malfunction which was interpreted as MAF failure when in fact it was just loose battery cable?
2) how frequently do both check engine and trac off come on together?
3) will i get a new check engine light if i keep driving and the MAF is indeed malfunctioning?
4) is my car eating gas like crazy because it needs a new MAF senor?
5) do i need a new sensor or can it be cleaned or should i not bother and just replace?
thank you!
thank you!
A: Very unlikely
A: Very frequent. The ECU turns off the electronic traction control when it detects some specific malfunctions in the engine.
A: Yes
A: Your engine is eating too much gas because the fuel trim is out of spec (too lean - P0171). Possible trouble areas: Air intake (hose loose), fuel line pressure, injector blockage, heated oxygen sensor malfunction, coolant temp.sensor and, of course, the MAF sensor is perhaps the best candidate in your case
A: A new unit is around 180 bucks and you don't even know if it is the culprit. Why don't you buy a bottle of MAF cleaner and give it a try?
A: Very unlikely
A: Yes
Only 1 code, P0171? That's Lean on Bank 1. MAF sensor is not related because it would cause 2 banks to go Lean at the same time. The intake gasket are on bank 1 and they do leak. Get it smoke tested to confirm the leak. We can rule out the oxygen sensor since you already replaced it.
thank you.
also, just buy it at autozone?
thank you!
just got around to doing this today.
[url]https://www.clublexus.com/forums/rx-first-generation/515386-diy-maf-mass-air-flow-sensor-cleaning.html[/url
much easier access. mine didin't look very dirty at all so i think i am going to have to resort to replacing the dang thing. will post an update.
but i have driven around about a week (maybe 25 miles of driving or so) but i have not gotten the error code again. does this mean the code was a fluke?
thanks!
thanks!
