Codes PO441 & PO446 1999 ES
I could use a tip on figuring out if this is a bad Charcoal canister? Is there a way to test the canister without taking it out? I've watched a youtube video on how to replace it and I don't think I'm going to do it myself. What about vac hoses? Is this a visual inspection? The car drives fine. I've had the codes cleared after installing a new gas cap and the check engine light came back on after 30 or so miles. Thanks for your help.
I'll give it a few weeks, I guess. I just got the car a week ago, replaced both knock sensors, wiring harness, rear struts, 2 tires, oil and air filter, and PCV valve. So I'm about spent for a bit! Maybe I'll try some black tape..
Investrx
ES - 5th Gen (2007-2012)
09-10-13 04:46 AM
