Bad Engine Noise
Bad Engine Noise
Good evening folks here posted is a video from youtube in which someone has the current problem that I do. Ive diagnosed and it dosn't seem to be the water pump, A/C compressor, or the tensioners. However after I got done reading more about it someone said it could possibly be the VVT-i gear gone bad!!! any suggestions that might be an assistance to this problem!?
Did you remove the belts one by one to see if the noise went away? No noise difference with the A/C on or off or when it cycles on or off like that one sounded?
VVTi gears? Have a video of that noise?
No I'll have to ask my mechanic to see If he removed the belts obviously you don't remove the timing belt. This video is a 2010 toyota camry VVT quite simliar to the ES300 setup..
Im going to have to check tomorrow from my mechanic and see if he ran the vehicle without the serpentine & p.s belt & if he did then it wasn't that... Also I forgot to mention two things 1.) This noise does occur when the A/C compressor is on & off but could be that its still turning the A/C pulley 2.) This noise does not occur on a cold start.. When engine gets to operating temp from just idling it commences that noise. As indicated in the two posted youtube videos!
This is just a guess, but I feel that if it was a VVTi issue, then the noise would have been a bit more muffled. From your video, it sounds like a spinning accessory/pulley. Also, how can you run an engine without any serpentine belts? You can't run the car without a working alternator, and the A/C uses the same belt as the alternator.
Another question too I have is there anyway possible that the timing pulleys can fail due to extensive wear creating that noise indicated in the 2 youtube videos up top?
I just had this same issue, it would make the same noise in the morning when I first start the car but would soon go away. I thought it was the A/C, the alternator, belts, etc... About a week after having this noise and trying to figure out where it was coming from, it finally died on me. Car started to idle very rough and then threw a crankshaft sensor error. Towed it to Toyota and this is what they replaced. Since they were in there, I had them replace all belts.
A. DIAG CHK ENGINE LIGHT CAME ON, BARELY RUNS, ENGINE DIES (CODE P0335
(Crankshaft Position Sensor Circuit Malfunction))
REPLACE CRANKSHAFT PULLEY, TIMING COVERS, TIMING BELT, DRIVE BELTS,
AND CRANKSHAFT SENSOR
Runs perfect and noise is gone.
i too have this noise..i think its inside the engine but it comes and goes...as if it has mind of its own..
http://www.youtube.com/watch?v=hKfvHCBlM1Q
timboat
10-17-17 08:32 AM
AntzCro
03-16-15 06:46 PM
