RPM start
I noticed an odd thing this morning when I started my car to go to work. The RPM needle shoots up to 2... normally, my needle stays around 0.5 or 0.75. Anyone ever had this happen on their car before? My engine felt the same though on the way to work, and my RPM needle settles back to normal when I make a full stop. Not sure if this has anything to do with it, but I got my oil changed yesterday at the usual shop, and they know my car very well. Plus, I park my car outside everyday, and this morning the temps were in the 30s, but no frost. I have a feeling the needle situation is just temporary for that cold morning, and probably won't show up when I go out to lunch. Feel free to leave any comments, thanks!
your car only does that for a few moments after you start it. This is because your engine is cold and trying to warm-up. normally it goes down when its at normal operating temp.
I have always noticed this with all of my cars. When the weather is a little bit on the cool side, or if you parked your cars for many days, the engine will rev @ approx 2K until the egnine temperature reaches its operating temperature. I believe this is very normal.
I assumed it was just the engine warming up also, but then again 2K RPM is awfully high for a warm-up speed. My mechanic checked out my car and said there's nothing to worry about, so I'll take his word for it.
That situation is totally fine.
I tested this.
Mine usually starts at about 2K also thanks to cold Chicago weather when parked outside. I don't push the car until the engine temp. needle reaches about midrange.
This morning, it was in the garage, which was heated @ 65 and it started off around 1K.
Conclusion: temperature is the factor.
I tested this.
panda08
01-24-13 11:25 AM
