motor mount replacement?
Well I'm guessing its the motor mount that is the problem. Whenever I drive up to around 40+mphs and let go of my gas pedal, I hear a clunking noise until I step on the break or gas pedal. How much am I looking at to get this replace? and how quickly should I replace it because my schedule is kind of tight since I have work and classes almost everyday.
well, there are three different motor mounts. 1 front, 1 rear, and 1 transmission.
i have a rear motor mount brand new/never installed that I will let go since I'm no longer in the ES scene.
rear motor mount - around $80 from Lexus
front motor mount- usually around $150 on ebay, but i strongly suggest not getting ebay motor mounts since they are almost always junk, so OEM will be more expensive
transmission motor mount - usually around $110 on ebay, but once again I strongly suggest OEM toyota
if you need a rear motor mount, Ill sell it to you for $40
goodluck with your issues
Charley
Charley
Forgot to update this, apparently I still have the codes but the clunking noises wasn't from a motor mount issue but my heat shield rusted out. Luckily I was looking at my engine today and my A/C belt is holding on by a thread I got it to the mechanic today hopefully I get it tomorrow
Forgot to update this, apparently I still have the codes but the clunking noises wasn't from a motor mount issue but my heat shield rusted out. Luckily I was looking at my engine today and my A/C belt is holding on by a thread I got it to the mechanic today hopefully I get it tomorrow ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
yeah its the catalytic converter's heatshield. it was just lying on top of the catalytic converter. The mechanic didn't fixed it it still rattling, I can just take it off right?
