97 ES300 Turn Signals and Hazards stopped working
Old 06-24-12, 12:51 PM
BriWill
BriWill's Avatar
Default 97 ES300 Turn Signals and Hazards stopped working
The turn signals and hazard lights on my 97 ES300 have suddenly stopped working.
I checked the fuses both under the hood and in the driver's side fuse box, and both fuses check out fine.
It think it must be the relay that has gone bad, but I can't figure out where that relay is located.
Can someone tell me where the turn signal relay is on this car? Thanks!
Old 06-24-12, 08:46 PM
Received 2,887 Likes on 2,440 Posts
Old 06-24-12, 09:35 PM
Hayk
Hayk's Avatar
When I was repairing my radio, I noticed that if you don't have the hazard switch plugged in, your blinkers don't work. Check to see if the connection is good. It's the panel that contains the clock.
You have to remove the center vents in order to get to the connector.
Old 06-25-12, 04:57 AM
BDSL
BDSL's Avatar
The flash relay is located beside your left shin when you are sitting in the driver seat.
Old 06-25-12, 07:29 PM
1987's Avatar
the turn signals and the hazards both go through the hazard flasher (relay) that will be the source of the problem
raj96es300
02-04-17 01:50 PM
Yohan84
SC- 1st Gen (1992-2000)
09-04-14 01:25 PM
supraclay
11-12-12 05:06 PM
ChasMax
01-07-11 09:18 PM
Quick Reply: 97 ES300 Turn Signals and Hazards stopped working
