How would you clean this?
Door Speaker Covers.
I would like to remove them to avoid any moisture getting onto the actual speaker. Is that possible or would I have to disassemble the whole door card? Both front doors have a few stains on the covers, which really bother me, since the rest of the interior is very clean.
![](http://i257.photobucket.com/albums/hh236/mjrgonorrhea/18507e73.jpg)
uhm no, the nylon clothe part of the speaker cover is glued onto of a plastic grille and it is screwed onto the door panel. just remove the door panel which is like 2 minutes..take the two screws off, slide off that cover and wash it gently...do not soak or the glue will soften and it'll peel off.
or just do it the safe way, just wash it with a towel or foam with a little water.
well i too had same problem..so i took Simple Green concentrate and mixed with warm water and then with sponge lightly dampened , i just scrubbed lightly and those stains went away..you might have to keep @ it..give it a try..
You dont have to worry too much about water getting on the speaker cones.
as long as its a small amount that will dry up and not on the electronics you're fine.
On the other hand, my tweeters are getting wet whenever i use a pressure gun to wash my car. Thats a problem.
Oxyclean ... Buy the powder and you can mix up a solution in a bottle to squirt on. This will rinse clean....would not use a toothbrush it will fuzz the fabric....use your finger. And for oil stains use Dawn dish soap...20:1 If you get the speaker wet...just dry it in non-direct sun...
