Window Motor Replacement - ES330
My driver window motor is out. I know all about the "hold the button and slam the door fix" and the problem is either the switch (cannot hear the click sound when you lift/press the window button), or the motor.
1) any ideas how to test the switch to make sure it is working? There are plenty of wires in the plug and don't know which ones to test. All the other windows work fine.
2) I know how to take out and replace the motor, but I don't know what I need to do for the motor to "learn" the up versus bottom position. Is there something like disconnect the battery, pump the gas peddle 3 times, and turn the radio on procedure?
Any help, diagrams, etc. would be appreciated.
My motor is about to go too for my '05 es330 driver side window.
Question2: i don't know if this is what you were looking for but its a video on a toyota camry on how to reset the motor. Are you going to purchase a new motor through the dealer? i've been trying to find a remanufactured one online but its out of stock everywhere.
