rack && pinion
Old 07-17-12, 02:34 PM
TOYfaanz
TOYfaanz's Avatar
Default rack && pinion
Does anyone know wat is the going rate to replace/fix a rack && pinion on my 98 es300?? Not sure if my car is worth spending money on it considering it has a salvaged title. I jus flushed brake fluid because it had 200 copper ppm in da lines. Changed ac, ps, and alt belt. And replaced dog bone mount. Lmk thanks.....
Old 07-17-12, 04:28 PM
PlatES300
PlatES300's Avatar
Not sure if it's worth it...I just replaced mine on my 2000 ES300 and it took two people almost 6 hours to swap out the entire rack. I got a rebuilt rack from rock auto which cost around 200 after the core is returned. You will get raped on labor - you have to remove the steering column from the inside to remove the rack and its a real pain if you're doing it yourself. If you know someone that is mechanically inclined, I'm sure they would help you. Good luck.
Old 07-19-12, 12:24 AM
TOYfaanz
TOYfaanz's Avatar
^^^^ how much did u spend? & yeah I was looking at the es book just cringing at what needed to b done.
Old 07-19-12, 02:09 PM
Gchutes
Gchutes's Avatar
I needed a rack and pinion about 4 months ago and got a refurbished camry rack and pinion put in for $600 out the door and that included a 4 wheel allignment. but then that still didnt solve my problems i also needed tires but after that i spent $950 and got a new rack and pinion 4 new tires and a 4 wheel allignment.
If your not sure your car is worth it being salvage title well thats up to you since you already did all that work there's not much more to be done and you will have a swag lexus but if your done with it get a civic these cars are reliable but aren't the cheapest to fix.
p.s. my car has 240k miles.
Old 07-23-12, 01:43 AM
TOYfaanz
TOYfaanz's Avatar
Damn sucks to hear that. **** guess I should sell my car. Faaaak!
isospin
ES - 5th Gen (2007-2012)
04-23-21 05:25 AM
foreste1
GX - 1st Gen (2003-2009)
03-08-17 01:29 PM
DJ8684
GS - 1st Gen (1993-1997)
08-10-14 02:47 PM
Lexus082
Performance & Maintenance
10-02-08 08:59 PM
Quick Reply: rack && pinion
