battery
my old battery died on my 2002 es300 ,i replaced it with a new one, put the battery in started the car drove around the block , i let the car sit for a couple of hours in the garage came back to start it but it would not start again .... is the alternator bad??? or is there another problem ...thanks
Put a multimeter on the battery. With the car idling you should measure at least 13.5 volts, off idle around 14.1 volts. If you are measuring less then that it's likely the alternator is not working.
Boost start your engine. Then remove the jumper cable. Let the engine idle. If the alternator is dead, the engine will stall in a few minutes. If it doesn't stall, either your new battery is not holding charge or something is draining your battery.
TurbodVq35
01-21-24 10:13 AM
masboy
03-04-12 06:37 AM
