Transmission Problem Es300 160K
Hello everyone,
I new here and was wondering if I could get some help. I own a 2001 lexus es300 with 160K miles. one day i started the car and there was a winding noise coming from the engine tranny. I drove the car to work and everything was fine but on the way back the noise got louder and the car went out of gear. Now when i start the car and its cold it will drive for about 30 feet and pop out of gear. Does this mean my transmission is shot?
thank you
thank you
Before you do anything else check your transmission fluid for proper level (engine idling and fluid hot)
Also Check for color and odor.
How long have you had this car?
Anything done to the transmission that you know of?
I have this car 3 years now. I have no idea if the transmission had anything done to it. When i checked the oil level it was good but the oil had a burnt smell to it..
Sounds like your transmission failed due to lack of maintenance.
Advance apologies for asking this question in this thread -
- 2005 ES330, 101k miles, well maintained
- transmission fluid pink/purple color, no brown or dark color
- lexus manual says change it at 60/120k only if driven primarily while towing
Does it need transmission fluid change or should I wait until I see any signs of trouble?
Added later - Saw response to my similar question by MrBooby in other thread -
https://www.clublexus.com/forums/es3...ml#post7370823
In case of emergency only. Brake fluid will really saturate / inflate. The seals nessesary to build the nessesary pressure ur trans needs to shift drive ect. But will eventually. Fail. So. If yo ist need to get to work. Until next pay period so you can afford tranny this will work. REMEMBER EMERGENCY ONLY THIS WILL ONLY RUN. FOR. SO LONG.
Hello everyone,
thank you
thank you
AabirRizvi
03-30-17 07:32 PM
AabirRizvi
03-30-17 04:20 PM
