How Many Miles Are On Your Es300??
#151
364,098 miles. I just got back from a 2404 mile round trip to the Finger Lakes area in upstate NY and then back to southwest MO. Used 82.3 gallons of 87 octane fuel for an average of 29.22 mpg driving right at 70 mph most of the time. Gas for the whole trip averaged $2.914/gal for a total cost of $239.76. Oil level is exactly where it was when I started. The car is still a quiet, smooth riding vehicle and the best I've ever owned.
#152
#153
Bought the car at 277,107 miles and would not have done that except for all the dealer repair/maintenance documentation which was pretty thorough. Since then I've done fluid drain and refills, spark plug and valve cover gaskets not too long ago, lower control arms, struts, rebuilt Denso starter, 4 oe engine mounts, tires, engine and cabin air filters, front and rear calipers and brake components, new Denso MAF sensor, oe thermostat and hoses, oe drive belts (a/c pwr steer etc), and I've only replaced one sensor: Bank 1 Sensor 1 Upstream Rear Air Fuel Ratio Sensor. I've not done all the work myself but most. Now, I'm coming up on it being time to do the timing belt/water pump R&R and I don't think I want to do that myself. Not sure what I'm going to do.
#154
#155
Hey djr48312! Thanks for the encouragement on the tb and wp. I think I need to read the procedures and watch the videos a whole buch more times before I decide which way to go on that.
I didn't think my front end was loose UNTIL I replace the LCR (along with all the other front end components around it). After the alignment was done the car drove straight and true and was much more responsive to minute steering changes. No wandering anymore. The bushings were pretty cracked but not all the way through. I used MOOG RK620334 and 33 from Rock Auto. Got those before I discover oe parts at amayama.com. So far so good.
#156
I'm doing all of it:
control arms and ball joints
Steering rack
steering lines
Maxpeeding rods 24 way adjustable Coilovers
Front bearings
Axles
Sway bar end links
rotor and pads done a year ago.
I want a more tight and compliant ride
will evaluate 2006 is250 rims
#157
Looks like a good amount of work to be done. Maybe start a new thread and keep us posted on your progress? Not sure about the bearings. ORO has a method that has worked for me to figure out if they're bad or not: Get the wheel off the ground, spin the wheel, while avoiding moving parts grab the spring, and, if you can feel any roughness it's most likely the bearing. Good luck.
#158
If it's my situation with literally the entire suspension and anything around it replaced, the reason was simple. The parts are very cheap. I can get both front wheel bearings under $50. The car has 240,000 miles, so I don't care even about testing the old ones. It's getting totally freshened up suspension wise.
So while you have all that stuff off to do the struts and control arms, you may as well do the rest, instead of going back in and out to finish the next part. I want a very tight and complaint ride and to be able to have control on the road.
djr48312 (10-04-21)
Hayk (11-21-21)
SDRider
16
05-14-20 07:56 AM
Wadeisabea
03-22-08 03:28 PM
