Audio Help! Put the subs in and worked fine for 5 day and now they don't work??
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
I have a 1997 Lexus ES 300 which I put 2 12 inch subwoofers and 2 tweeters ( one unit ) it is a full range unit with a total of 1000 watts in place of the back deck subwoofer witch is like 8 inches. I cut the wire from the blown stock woofer and stole the wire off of the original wiring to the back deck subwoofer and wired it directly to the aftermarket speakers. The speaker’s worked great for about a week and then all of a sudden now all I hear is background music what could possibly be wrong? I though it could have been because I didn’t install my amp but how did it work great for 1 week and then all of a sudden go dead. The way they worked really good is if I put the fade all the way to the back of the car directing all the sound to the speakers in the trunk. Now I put the fade all the way and it sounds like its only half way and the sound is trying to come out of the back seat door speakers. Should i disconnect all the speakers in the car except the subs? seeing most of them are blown. Or should i just replace all my speakers. Also how could i remove the door panels? Also i tested these speakers on my home stereo and they worked fine also it may be a fuse in the car not sure
Any suggestions?![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
Thank you for the help sorry if im asking a question thats already asked before. if so please direct me towards them.
Ryan
Any suggestions?
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Always a bad idea... unless the subs are made specifically for your factory amp. Subs and tweeters all in one? Typically subs require more power than speakers and tweeters even less. So 1000 watts is probably the peak power and you (OP) want to find the rms power rating. Best buy does install and just call or drop in for a quote. Might be a little more to fix the previous install.
Was this 1000W unit perhaps already powered on its own did you run a power wire to it or just the speaker wires? It does figure you would blow the amp if trying to run all that off the sub channel in the little old stock amp.
The stock amp is behind the glove box.
you took 0 consideration of the amp capabilities. Car audio is alot more complicated than plug and play. You need to check the ohmage of the subs, speakers, tweeters. and make sure they can run on the amp. Regardless this is a bad idea to say the least. Invest audio the right way or not at all. Get a good monoblock amp for the subs, dedicated amp for tweeters and mids.
![Big OK](https://www.clublexus.com/forums/images/smilies/bigok.gif)
Just the speaker wires (hacked off of the top deck speaker) hopefully the installation of my amp will fix it. thanks!
could their be a fuse blown? also if the amp was blown no speakers would work all the other speakers work. Also i check to see if the subs were blown and they work fine in my home audio system.
you took 0 consideration of the amp capabilities. Car audio is alot more complicated than plug and play. You need to check the ohmage of the subs, speakers, tweeters. and make sure they can run on the amp. Regardless this is a bad idea to say the least. Invest audio the right way or not at all. Get a good monoblock amp for the subs, dedicated amp for tweeters and mids. ![Big OK](https://www.clublexus.com/forums/images/smilies/bigok.gif)
Thanks
Actually it is the reverse of your logic, if a fuse was blown all the other speakers would not work as the whole amp would be dead. In the case if the other speakers work, you likely blew the sub channel that you hooked that speaker menagerie up to, but the other 4 channels continue working so you have sound in the other speakers.
Okay, first of all... what's the brand of sub/tweeter that you have? Is it one of those all in one things that they sell at places like Walmart or even Best buy or did you get a box and add the parts in? Does it have an amp on it or did it have no power except from the car amp? FWIW, I would never let best buy hack into the electrical system in my car....
