ES300 Steering Wheel Starts to Shake Around 60+
I've noticed that my steering wheel starts to shake around 60+ mph. The rest of the car feels fine but it's quite noticeable in the steering wheel. I've looked elsewhere, but I've yet to find a solution. I've heard that it could be the nuts, tires, unbalanced wheels, and countless other things. I haven't had it checked out since I would probably be ripped off by some of the local shops, not to mention I sort of doubt they'd even be able to diagnose the problem. Other threads have been posted about similar problems without a defining answer. Has anyone experienced this? Has anyone been able to fix this problem completely?
As you said, it could be a lot of things. A vibrating steering wheel is one of the hardest problems to diagnose.
Possible causes: bent wheel, unbalanced tire, loose tie rod end, warped brake rotors.
Start with a quality shop and do a dynamic balance. If the wheel is out of whack, they should be able to pick it up on the machine. Go from there.
Mine was fixed with a simple but quality wheel balance.
Agreed^ Quality wheel balancing should be a routine job for any tire shop. Unfortunately, it is not the case.
I'm currently having the same problem with my 99 ES300. The wheel begins vibrating at highway speeds and gets pretty violent as I touch the brakes. Are you experiencing any issues other than when at highway speeds? I do not see any symptoms unless I am on the highway. It begins while I am driving along and gradually gets worse. Is this what you're experiencing?
