Chroming it up a bit
I really like this mod. Simple, OEM and elegant
Can anyone help me out with the part numbers for a black interior - I'd need the chrome door handles and the Avalon shifter ****, both in black.
Much appreciated!
Much appreciated!
Official response from Sewell.
Originally Posted by Sewell Parts Team
For some special edition models such as the case with the 2001 ES Coach Edition, those parts specific to these models are not openly conveyed in catalogs. In this instance, the driver side interior handle has already been discontinued and is no longer available. There might be a single passenger handle available in the country. It would seem an upgrade would be futile as both front handles cannot be obtained.
^^The Avalon shifter trim is chrome, there is no color specific part of it, it is just the shaft cover so the part number I gave in the first post is what you need.
you can try maybe to find the chrome handle parts used on EBay, or shop the part number around to Toyota dealers, it might not be that rare, though what Sewell says is right, like for a part like anything in the Coach edition only maple wood trim those parts are super expensive or discontinued.
But the chrome handles with black lock button, those are pretty common, some Camries had the chrome handles too, not actually a Coach specific part.
Part nos below should be it for front Coach with black... note from first post you don't need the bezels but if you don't want to trim your stock one to fit the chrome handle you can buy the correct bezel.
BEZEL, FRONT DOOR INSIDE HANDLE, RH 69277-47010-C0
BEZEL, FRONT DOOR INSIDE HANDLE, LH 69278-47010-C0
HANDLE SUB-ASSY, FRONT DOOR INSIDE, LH 69206-22080-C0
HANDLE SUB-ASSY, FRONT DOOR INSIDE, RH 69205-22080-C0
