96' es300 CV Joint Replacement Question
Hi all,
My 96 es300 needs new axles on both sides... the boots failed long ago and now the axles are going.
I was wondering if anyone can help me. Im trying to purchase parts all in one go so I dont have to pay extra shipping.
Does a CV Half Shaft Assembly come with everything I would need for this replacement?
Do I need a new CV Joint Boot or Output Shaft Seal?
Is there anything else I would need to replace?
Thanks for the help!!!
nowadays I thought these shafts were pretty cheap to replace as a complete unit. lotsa work to rebuild.
i was told on the driver's side you can remove inner first (bolted on like a VW style), then remove, pull out the outer side and not have to touch the hub, tie rods, etc... Anyone done this, or able to verify? I have to swap out 2 tonight...one from my parts car and one into the daily driver.
canucklehe
01-27-13 10:08 PM
caladuke
07-26-04 02:59 PM
