Update: Your springs arrived on my doorstep today and I immediately installed them when I got home from work. I just finished about 10 minutes ago and the result is great! The car sits perfectly even now, and the rear is quite a bit lower than before. There's only one thing I'm worried about now; what if when I install my new shocks, it makes the car sit unevenly again?
It is the springs afterall that are supporting your cars weight. The strut damper is just there to control the oscillation generated by the spring when you go over a bump, i.e. blown shock = bouncy ride.
Or make me one of those Heat shields for your intake that you have and i'll be happy too. I'm quite negotiable
Honestly I would, but you have the 3VZ-FE engine so I don't think mine would fit you. But, I do have a "prototype" front lip that I've been working on. I might think about sending you one of those.
Haha true, forgot about that. I guess I could make another one, although I'm not sure how I can measure the top edge so that it sits flush against the underside of the hood. The Avalon has a different hood shape than the 2ES. Other than that I can give it a shot.
