Weird lowering springs result
I just installed H&R's on my '94 ES a couple of days ago, and the F/R drop is weird. It appears that the front was lowered considerably MORE than it was supposed to be (based on the H&R website, which states a 1.3"F/1.25"R drop for these springs), and the rear was lowered AS MUCH or LESS than it was supposed to be. The car now has this super rake stance that I don't like at all. I know the springs are supposed to settle over about 2 weeks or so, but that still doesn't explain why the front was immediately lower than it should be. Does anyone know what the explanation might be? It's possible that it's just because of the weight of the engine, or that I might have been shipped the 4-cyl Camry springs by mistake.
I got mine lowered a week or two ago, and i could only barely tell the difference from stock at first, once they settled it was all good though.
Sounds like a spring screwup unfortunately. They didn't have part numbers stamped/printed on the springs for you to check?
I just thought of something else. Only the front shocks have bumpstops and the rear don't. I trimmed the bumpstops on the front down to 2/3 of their original length when I installed the springs, even though the directions didn't mention them at all. Could that possibly be the problem?
Ok, I finally have pictures. Here are the pics of the ride height after installing the springs and letting them settle:
![](http://i1148.photobucket.com/albums/o576/AlphaOnion/IMG_0351.jpg)
![](http://i1148.photobucket.com/albums/o576/AlphaOnion/IMG_0352.jpg)
![](http://i1148.photobucket.com/albums/o576/AlphaOnion/IMG_0353.jpg)
As you can see, the front is alot lower than stock. Way more than 1.3 inches. The rear has dropped noticably, but not nearly as much.
Here are a couple of pics of how I would like it to look (these were taken with about 250 pounds of weight in the trunk to even out the springs):
![](http://i1148.photobucket.com/albums/o576/AlphaOnion/IMG_0354.jpg)
![](http://i1148.photobucket.com/albums/o576/AlphaOnion/IMG_0355.jpg)
Any thoughts?
Any thoughts?
do not ever cut springs please. your lexus deserves better than that.
i'd say stick with it for a while, say 3 months. if you are still not happy, then get another set of springs.
on a less serious note, u can start hauling some fat chics to get ur desired stance
thatta boy!!! break em in while breaking your back seat playa!!!
