ES300 Timing Belt Costs?
Old 09-12-12, 10:02 AM
saltytx
saltytx's Avatar
Default ES300 Timing Belt Costs?
Hello all- I have a new to me 1998 es300 with 125k miles. It hasn't had the timing belt replaced yet. In calling for estimates, I looked to replace the following: timing belt, water pump, crank seal, cam seal, tensioner and idler pulleys and the thermostat. I've gotten back estimates from a Lexus dealer for 1317 and a good indie for 1265. Both seem high to me. Shouldn't this job be more like 800-900? (Searching this forums brings up costs in this range)
I'm in Dallas, and if anyone has a good recommendation for a mechanic let me know, Thanks!
Old 09-12-12, 11:34 AM
Hayk
Hayk's Avatar
Considering that it's a dealer, the price is about right, but for an indie shop it's way too much.
You don't need to replace the thermostat, don't worry about it. Don't forget that you probably need the accessory belts (A/C and Power Steering). I would recommend getting the AISIN kit from RockAuto, it comes with a hydraulic tensioner, water pump, two pulleys, and the belt - it's $180. Then you will also need three seals (crankshaft and the two camshafts). Those you will need to get from the dealer - very inexpensive. You can also get the accessory belts from them. Since you're in Texas, I would recommend using Sewell Lexus (they have a discount for ClubLexus members).
Once you have all the parts, find someone who will do the work for you. Oh and finally, you will need about half a gallon of Toyota Red coolant, if you're not planning to drain all of it.
It shouldn't take more than 4 hours for a Mechanic. I bought all my parts from the dealer and had a buddy install them.
Old 09-12-12, 02:33 PM
saltytx
saltytx's Avatar
Thanks for the info, I am 50/50 on doing the project myself and the repair estimates might push me in that direction. I got the quote above from Sewell, and while they do have great customer service, the price is high.
Old 09-12-12, 05:48 PM
hzt30
hzt30's Avatar
You could try a Toyota Dealer after all the engine is the same as a Camry V6.
mzeitlin
02-02-12 04:15 AM
stant_98
13
11-22-09 08:20 PM
BA_GS400
Performance
12
09-07-06 06:21 PM
John U
Great Lakes
05-31-05 07:14 PM
hrusky17
05-20-03 05:02 PM
Quick Reply: ES300 Timing Belt Costs?
