New Spark Plugs.. Motor has a "miss"
09-13-12, 08:31 AM
Hey everyone. I put new spark plugs in my 1996 ES 300 last night, and I noticed this morning it has a slight "miss" or "kick" once in a while while driving. Any thoughts or advice on this would be great. Thanks everyone
09-13-12, 09:15 AM
I take it that it ran OK before the new plugs??
Did you use Denso or NGK spark plugs? Did you check the gap on the plugs?
09-13-12, 09:18 AM
Find out which cylinder is missing and inspect the secondary ignition system.
09-13-12, 09:19 AM
It did run ok before the plugs. I used pre gapped Toyota plugs.
09-13-12, 09:56 AM
How would I go about finding out which cyl. is missing?
09-13-12, 10:39 AM
Is your check engine light on? A steady misfire would cause the check engine light to blink and therefore set a code indicating which cylinder is at fault.
09-13-12, 11:23 AM
09-13-12, 01:34 PM
Check for any codes, there may be a pending code which will tell you which cylinder has a misfire.
09-13-12, 01:56 PM
Perhaps you haven't plugged in the coil connector all the way. They get brittle on some 1MZ engines. Worst case scenario could be a bad coil...
09-13-12, 10:17 PM
No CEL. Could be the old wires and new plugs combo. Just puzzled by it. Should I throw the old plugs back in until I get new wires? Do I need to use Toyota wires or is there a good after market brand out there?
09-14-12, 12:06 PM
09-14-12, 12:17 PM
Quote:
Originally Posted by
nicks88
May as well just go OEM here, the original set comes with the plastic sheath and clips already installed. Do a search for OES1615180
09-14-12, 12:49 PM
If there in no CEL you could have a pending code in the ECM. Did you scan for codes?
Disable one cylinder at a time and see which one does not contribute.
09-14-12, 01:27 PM
In Recovery Mode
You always replace the wires when you are replacing the spark plugs, that's what I do. Replace the wires!
KTGS300
01-07-18 02:08 PM
imAC
12-03-13 09:51 PM
canoswagg2
08-29-13 10:32 AM
LDNN
06-22-12 05:03 AM
thaeleelyr
RX - 1st Gen (1999-2003)
12-22-10 05:44 PM
1996 ,
1999 ,
engine ,
es300 ,
gap ,
install ,
lexus ,
miss ,
plug ,
sc400 ,
slight ,
spark ,
sparl ,
view ,
wires
