Anything that bugs you about your ES?
well its def a design flaw..i think the cupholders are not deep enough to hold the bottles in place..If you look @ newer ES ( or any other car) the holders are very deep. And almost like 40% of the bottle is "sink" into the holder. I think if our ES were deeper then it would def hold any bottles in place..
Another thing to mention is the rain-sensing wipers. What stinks is if you start the car with water already on the windshield, you need to switch it out of "Auto" and then back to activate the system, otherwise it won't "calibrate" itself correctly. And down here in south Texas it gets mighty hot in the summer, which causes the wipers to randomly go haywire at around 100 degrees. Almost makes this feature not worth it.
The frameless window was one of the biggest design flaws, it was a dumb decision for something cosmetic that I'm willing to bet most ES buyers didn't even notice until after they bought it.
A car like this should be all about making the driver feel like they're in a cocoon. When I'm driving at highway speeds, the wind noise is really bad. I've make some "ghetto" alterations that have helped (like putting foam behind the weatherstripping to push it into the glass and some silicone paste) but the whole car probably needs new factory weatherstripping from the dealer, which isn't cheap. A traditional framed window even after many years would be fine.
What really bugs me on my 2002 ES is the floor button "hand brake." Try using that when you're on a steep hill waiting at a red traffic signal! My 2004 Camry with the console-mounted hand brake makes this so much easier. I thought the floor brake went out with 65 Oldsmobiles!
Well, when I had a manual transmission, I was instructed not to use the clutch to hold the car in place when stopped on a hill- that this burns the clutch disk out. Do you mean you can just hold the ES on a hill using the gas pedal? Sounds like the same thing to me... Here's a link (see item 1) http://www.wikihow.com/Prevent-a-Car...Back-on-a-Hill
So- right foot on the gas pedal, left foot on the brake? We're talking San Francisco hills by the way! That means up to 1:4 grade. My solution so far has been to not drive the ES in San Francisco!
yea thats what I do when I'm starting from a stop on a very steep hill to prevent my car from rolling backward into the car behind me. Shouldn't hurt your brakes too much since you only need to hold the brakes long enough with your left foot to prevent it from sliding back a couple of inches when transitioning your right foot from the brake to the gas pedal.
Can't believe I forgot to mention this, if the temperature control is set to COLD, every time you start the car it auto sets to recirculate. Very annoying.
SharpGent
10-08-16 03:48 AM
CalboyF
RC F (2015-present)
11-11-15 09:17 AM
