A/C BLOWS HOT even after freon
Old 09-15-12, 04:19 PM
lexus94es
lexus94es's Avatar
Default A/C BLOWS HOT even after freon
i just bought a lexus 94 es300 and the ac blows hot air or the tempurature o?outside more like it and right now its like 110 degrees so the ac is blowing really hot , so i figured the system needed a recharge so i went to autozone and bought on of those self rechardge things and still blowing hot air
the compressor comes on and stays on can someone tell me whats going on or some clues?
could the system have been so empty that it just wasnt enough? i heard that if the compressor comes out that it isnt a recharge thing? maybe cabin air filter or a blockage somewhere?
help!
oh and the car only has 100000 miles on it
Old 09-15-12, 04:29 PM
Received 2,901 Likes on 2,447 Posts
You can't just start putting refrigerant into the system and hope for the best, the problem has to be diagnosed properly. If you don't have at minimum a set of manifold gauges and some basic knowledge of A/C systems, then it is best to take the car to a professional.
Old 09-15-12, 04:37 PM
hypervish
hypervish's Avatar
Welcome to Club Lexus!
A/C systems require proper equipment. They are not very DIY friendly.
Did you use a gauge? Or did you just add Freon without checking how much was in there first?
Old 09-15-12, 04:40 PM
Eric The Car Guy has some really good videos about A/C systems, well worth watching. You will see that it is hardly a simple system to deal with, you HAVE to have the right equipment and know what you're doing.
www.youtube.com/watch?v=lglPJuBXVeE
Old 09-15-12, 04:41 PM
GSteg
GSteg's Avatar
Should have left the car alone. Those autozone stuff is okay for topping off, but that's about it. If you had a leak and there was no more refrigerant, then you just opened up a whole can of worms by adding some. If the system is empty, it can also mean the oil leaked out too. Running the compressor with little to no oil is just like running your engine with....no/low oil...
Bring your car to a shop and have them hook up the manifold gauge to see what both LOW and HIGH sides are doing. If the system is completely empty, then it needs to be vacuumed to check for leaks and pull out any moisture. Adding refrigerant to a system without having it vacuumed is a recipe for disaster. Air/moisture is very detrimental as you can form frost within the line and that will clog up the system.
lexus94es
lexus94es's Avatar
i have a shop available for use on monday my buddy works there and theres a certified a/c pro there so i just got impatient i guess and was hoping for an easy fix but i guess i'll have to wait till monday , FML
Old 09-15-12, 04:43 PM
lexus94es
lexus94es's Avatar
thanks yeah ive watched all the eric the car guy videos like i said i just got impatient but i was sure to put in a refrigerant that didnt have the leak sealer stuff in it
Old 09-15-12, 09:49 PM
Gerson
Gerson's Avatar
Check for wet residue where lines meet and expansion valve. That would be a good indication that your leak is coming from there.
Old 09-16-12, 08:27 AM
MikeLex
MikeLex's Avatar
Good bet -> clogged expansion valve.
actman
RX - 3rd Gen (2010-2015)
26
06-27-15 12:14 PM
Lveyolfe
07-01-14 04:53 PM
martay_guy
04-25-08 06:26 PM
dmd85059
07-09-07 05:05 PM
Booner
Maintenance
07-13-05 05:06 PM
Quick Reply: A/C BLOWS HOT even after freon
