Oil Light
The oil light on my ES300 won't turn off. The oil is fine and I replaced the oil about 1,000 mile ago. I don't know if I should be worried, my mechanic said no. He said this can just be a faulty light or the oil is dirty or a million other things that don't matter. I wanted to turn to my Lexus owning family and see what they think.
It could be your oil pressure switch. Remove the wire from the switch with the key on. If the light goes out and you have good oil pressure then the switch is bad or has a bad ground.
angelmom38
Performance & Maintenance
07-28-17 11:26 AM
