Antenna mast
I have replaced antenna mast on our 96es300 2 times so far. Every time it works good for 2-3 days then it rips out plastic gear drive out of mast and won't work anymore.
Any tips/trics to this?
Did you just feed the new mast into the unit, or did you disassemble and clean up the old grease? There also may be pieces of the old nylon cord stuck in the assembly causing problems.
