ES 300 Fog Light Case Replacement Help
I'm working on replacing my current fog light with a HID 12000k light. However the casing, is highly texturized and the nice bright and purple tint is being distorted. Is there a way to remove the old casing and replace it with a clear casing so the light comes out clean and brighter? Thanks for your time!
(you can see the texturized fog light casing in this photo)
![](https://www.google.com/imgres?um=1&hl=en&sa=N&biw=1363&bih=735&authuser=0&tbm=isch&tbnid=WxlAAhXwLmghgM:&imgrefurl=http://www.carbuffs.com/lexus99eschamp.htm&docid=9RknQBJjRoeHvM&imgurl=http://www.carbuffs.com/lexus99eschampext1.jpg&w=700&h=429&ei=FTd7UOrCLJG-9QTZioC4Ag&zoom=1&iact=hc&vpx=646&vpy=463&dur=89&hovh=176&hovw=287&tx=166&ty=97&sig=116991571620997392795&page=1&tbnh=141&tbnw=236&start=0&ndsp=20&ved=1t:429,r:17,s:0,i:123)
Hey there, Well your out of luck because it looks like you got the 97-99 Bumper and fog lights, The 00-01 have the clear lens fog lights. I don't know if its possible to change those lens and putting clear ones but i wouldn't bother if i were you even 35 Watt HID's melt the housing on this fog lights.
Thanks for the reply! I had no idea that those panels could melt. Would it be possible to replace those panels with some clear/glass aftermarket panels or just take them out and install project fog lights?
