License Plate Bulb Replacement Trouble
hey got a 2005 es330 and i cant figure out how to replace the license plate bulbs. got the emergency handle off and cargo liner on the inside but idk how to get to the bulbs! i see the clips i gotta get to but they wont budge. please help
On my 98 ES300, the license plate lights are accessed from the outside. You just have to push on the plastic clips that hold the clear lenses, and then it's a matter of pulling out the whole reflector assembly and swapping the bulbs. Is it way different on the newer body style?
On the newer bodies you have to access them from the inside just gotta remove the emergency latch and all the liner clips then there's some clips behind all of that but you have to really pry them out with a flat head cuz they never been removed before just needs a lil muscle that's all they'll come out I have an 04 and it was the same way
On my 2002 es300 only way to do this was through the trunk. U needed to remove the emergency latch and the clips that hold the liner on the trunk near the license plate. Once that was removed changing the bulb was easy.you just needed to peel the liner back and get access to the bulb holder. The tricky part for me was to find a way to remove the emergency latch. Attached is a picture of the latch handle dismantled so you can figure out how to take it apart with out breaking it. Hope it helps.
There's a thread about this already.
4ES license plate light DIY:
https://www.clublexus.com/forums/es3...ate-bulbs.html
