Coolant drain plug leaking. What are my Options?
Just got done changing the coolant on my 97 ES300. I noticed today the coolant seemed a little bit lower than when I originally checked it. While the engine was running I heard a faint "tsssss" and a little white smoke coming up. Sure enough right below the front drain plug I see it pooling and slowly dripping. What are my options? Maybe cap it?
Definitely check the o-ring.
I can't remember if the front drain plug has an o-ring on it or not. The back one definitely does. If necessary you can always replace the following:
90910‑09087 PLUG, WATER DRAIN ****(FOR CYLINDER BLOCK)
90910‑09095 **** SUB-ASSY, WATER DRAIN(FOR CYLINDER BLOCK)
2nd listing is for the entire assembly that threads into the block, first is only the drain plug bolt itself.
I can't find any pictures for the entire assembly, but I imagine that is replaced by unscrewing the much larger hex looking bolt that encompasses the smaller bolt that is normally used?
That would be correct. But before you go replacing it, try and find out why it's leaking. Perhaps there is crud in there preventing the bolt from threading in all the way? BTW what do you mean you tightened the bold "by hand"?
I still need to look for an o-ring as mentioned before, although I'm not exactly sure if that's the problem since that would presumably keep it from leaking at the screw and not the actual drain port. I was also considering just capping off the actual drain spot and keeping the leak at bay that way.
I thought that's what you meant, just making sure you didn't finger tighten the thing. Either way pull the plug out and have a look at it, and use a mirror to see if there is anything preventing it from snugging down correctly. You could always put some RTV on the threads that would probably stop the leak, but not an ideal repair.
If there is an o-ring and it's bad, then probably the first place the coolant would go is the drain tube.
It doesn't really matter where the coolant drains from, just fill and bleed the system as per usual. A good way to make sure minimal air is trapped is to fill the system slowly, and also run the engine for 10 seconds several times as you are filling.
Well I went ahead and put a little muscle into tightening the bolt and it seems to have stopped the leak. Not sure if over tightening is a major issue with this part, but I think the bolt is beginning to round out. I now face the dilemma if I want to risk draining it again as I planned, or leave it be.
