'94 es300 fuel gauge/needle light not working
Greetings:
First time, appreciate any help. Replaced light behind temp gauge and now fuel gauge/needle light do not work. All else fine. Understand there is a gauge sub-assy/fuel receiver that bolts into back of circuit board (P/N 83243-33010)? Can this be done easily as I have access to used cluster? Car has 50K miles. Thsx.
Check with OLT on are site, he does this for a living, mine are the same though, the led lights in the needles are broken dont work anymore, hope this helps you. Its a common problem on our cars, couse of the voltage drain when lights are on.
Thsx. This is a 50K mile car and everything worked until I pulled gauge cluster to replace light. Perhaps I disturbed other end of board where fuel gauge sub-assy is located? How do I reach OLT??
We do the lighting and have any needle that you need in stock.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
![](https://www.clublexus.com/forums/signaturepics/sigpic178522_1.gif)
262-456-4147
Hi jason, did i see your service offered on ebay? basically repair cluster lights?
I have no light on my speedo needle, and the left half of my cluster doesn't illuminate (was hoping maybe that problem is just a burnt out bulb....dare i dream that bulb could be relatively easy to replace??).
how hard is it for a DIY like me to repair this and get parts from you?
I also have some lights out on my ACC, left side aswell. is that repairable?
I have a 1993 ES300
I have a 1993 ES300
Replacing is not that bad, except there are many screws to deal with. There is a Post from lexusk8, dtd 12-29-03, that shows the back of the instrument cluster and identifies the lights. Many other Posts, over the years, that address the correct bulbs, etc.
Thermactor
17
11-06-11 11:14 PM
Iansaltes
08-26-08 08:38 AM
