2000 Es 300 transmission problem pls help!!
I packed my Es 300 this afternoon after running some errands. Later this evening I wanted to go out but the vehicle will not reverse. It only goes forward when you shift to drive but nothing happens when you put it on reverse. Please help!
It happened to me this summer. The check engine/trac off should be lit on the dash as well.
It happens in Toyota vehicles it seems. It's the vehicle speed sensor malfunction.
Fix? Take it to a mechanic, have them clear the codes and it will be fine.*
*This was in my case, and others' that i've read on here...
gflvette2
08-15-10 10:44 PM
