E-Brake Install/Troubleshoot
I have NO E-Brake. I can pull it up all the way, and I just hear scraping. How do I go about repairing this? Yes, I sound like a n00b....
It sounds like you just need to replace the e-brake pads. They work like drum brakes. Assuming the scraping noise is coming from the rear and your e-brake cable is intact. Start by jacking up the rear end and removing both wheels, calipers and rotors. From there the e-brake assembly is visible and it should be evident whatever the problem may be......stuck or worn down pads, frozen assembly or springs.
LentoGS300
08-27-18 06:03 PM
jaskillz
Suspension and Brakes
03-28-12 09:05 AM
masitaly17
12
08-21-08 10:46 PM
4double0
10-19-03 09:52 AM
