Awful coolant leak 1996 ES300, under the intake manifold.
#46
can anyone please provide part number for this hose? I explained to toyota parts lady that I need the coolant hose under the intake manifold, but she said their parts diagram was poor and didn't clearly identify it.
I plan to replace my knock sensors, which I believe requires re& re of intake manifold, so replacement of this hose would seem to make sense. but no part number is frustrating.
OR, what is the complete, proper Lexus name for this hose?
thanks
thanks
#47
If you pull that manifold, do replace that hose. I'll see if I still have the receipt. I think I had to call another Lexus dealer out of town to get the PN. Or I got it from the Toyota shop down the street.
#49
thanks
thanks
16261-20010
HOSE, WATER BY-PASS, NO.1
#51
Ok, I remember now. I found the part number on-line from a dealers website that had all the parts listings on his site. I found the link to the dealer here.
Our local dealer did NOT have the part in stock (which I found hard to believe, just supports the fact that the older cars, 10+ don't see the dealer often), so, they had to order it and it came in 2 days.
#52
thanks
thanks
#54
On mine, the engine type is stamped into the front engine block when you look at the engine from the front of the car. It says 1MZ. It is sideways, vertically. If that makes any sense.
#55
okay, I'll look, shouldn't be too hard.
and thanks very much for those links. awesome write up .
on the 3vz engine, they seem to show a solid metal coolant tube under the intake, but not a hose like the others. that'd be a bonus.
#57
tomf posted a great how-to link from Toyota nation site, for a 93 camry on my knock sensor topic . strange thing is, looked like a solid metal coolant tube with no hose, under the intake manifold (=bonus) . Also, when I looked on ebay for that part number, I thought a couple links said production date 06/93 or newer. so more digging needed.
#58
Usually there is a plaque on the driver's frame or door that lists the date of manufacture. Check that to find out when your ES was manufactured.
#59
It is just a coolant hose. I did not even consider getting "Lexus " hose from the dealership. I just went to Autozone and bought a foot of hose, cut to length and installed. That was 2 years ago and it is still working fine.
#60
strange, cuz if you read this whole thread, I think RSpi had issues using an aftermaket hose cuz wrong I/D ?? can't recall, but he tried to use something different and it wouldn't work.
silentc40
11-30-16 07:44 PM
