Engine Noise
I currently in my 92 ES300 have two amps, subs, and all aftermarket items in my car. I get this engine noise and have tried everything. Today I saw a post about the factory amp causing this problem so I disconnected it. That made things worse. I know it has something to do with the amp but I don't know what. Any ideas?
Well okay let me give you my set up first:
Two MTX Terminator Subs
A monoblock Hifonics Amp
A 4channel Boss Amp
Kenwood Excelon KDC-X395 Headunit
I have got a great ground
No speaker wire touches power wire
This noise changes when I accelerate but also I get a kind of popping noise when I first turn on the car as well. If you can help with either of these I would appreciate it and you would help complete my system.
A 4channel Boss Amp
Diagnosing a noise without hearing it is very difficult, so I was trying to figure out what kind of noise it was. Ex.: Ringing, Howling, Knocking, Hissing, Clicking, etc..
From what I have gathered is that it's a rotational noise and it changes with engine speed. I would check the alternator, because you're working with electrical components. The alternator has brushes that can make all sorts of noises over time.
No I told you its engine noise through the speakers not alternator noise the alternator is fine. The first noise is a humming noise that increases with rpms then theres a popping noise that happens when I turn the car off/on
You likely need to buy a ground loop isolator.
Please excuse me I meant no rudeness as you can well imagine it is an annoying problem but I don't want to sound rude for your help. I was thinking about running a separate power wire for the radio to the battery with an inline fuse of course. Do you think that would help because I know the problem is because of this factory amp that has not been properly dealt with. Again sorry for sounding rude.
APU6speed
06-30-03 10:58 AM
