Engine misfire at cruising speed
I posted a different thread about my engine shaking, which I believed to be related to the IACV. However, the the misfires are also present when I am at cruising speeds. From what I read, an IACV is highly unlikely to cause misfires at speed. Could anyone help me figure out what could be causing this. The shaking does get worse at idle, but under light load I also feel a slight misfire in the engine.
PLEASE if someone could point me in the right direction it would be greatly appreciated.
Misfires are not good for the catalytic converter. You need to see if there are any codes stored. It will tell you which cylinder(s) are misfiring or you might get a random misfire.
Shahabi8
06-13-19 05:21 PM
Niko1981
03-07-08 07:07 PM
