Suspension/Lowering Questions HELP??
Whats so bad about pillowball tops? i had them on my s13 rb25 silvia and they didnt cause any prb.
Depending on how low you want to go on your coilovers I would say stiffer rates if you wanna slam it. Also if your planning on having alot of weight in the trunk.
And I also would agree with the BC kits being the better choice if I had to choose
Oh ok that makes sense but do you not think that over so many years that other companies would of made the ride a little better with pillowball tops? Do you think that I shouldnt get the ksports with pillowtops on the front and rear? I'm doing it because i can get more camber out of pillowtops with camber bolts then just the bolts by them selves.
Ok thanks for your help but one more thing. Ksport can give me three different spring rates for the set. I heard that there spring rates are stiffer then they realy say they are. Ksport said that i can get 7.5k front 5.1k rear or they can do 8.7k front 6.7k rear or they can do 10k front or 8.7k rear what would be the best spring rate for lowering and still have a comfortable ride?
sneakyazn
Suspension and Brakes
08-24-08 07:26 PM
