Gas mileage
Super Moderator
hey guys, i know where the pcv valve is but i dont have a car anymore to tell you guys or take pics of it so i can show you i am upset about that and i am blabbing on and on and on yah but the pcv valve is left of manifold......and yah do be careful when taking it out the lil grommet hose is fragile.
When you get it back, post your mpg with the new valve. I'm curious to the increase. It may take an entire tankful to get a good average.
There is a recent thread under Maint. that talks about PCV valves on different models, but your discovery describes similar placement.
sj
sj
Well, i got the car back from the dealer yesterday. I figured i could change the grommit myself and save a few bucks so I told the dealer not to fix the car. I went out to the toyota dealer and bought a grommit for $7.00. I fished out the broken part of the grommit and replaced it with the new one. The car runs great now, much smoother ride w/ more pick-up. I will post pics of the old PCV valve when i get the chance. Unfortunately, I cannot post if my MPG will change or not yet. I am leaving for California today and wont be back for 3 weeks. WooHoo!
Here are the pics!
This is the Old PCV valve.
Carbon Deposits on the Old PCV valve, got 160,000 miles worth of carbon on there.
This is where the PCV valve is located.
This is the closeup of where it is located.
I hope this helps everyone.
Guest
Posts: n/a
HO HO HO
It's your K&N sir! The PCV valve is a good idea too.
Even slightly harder driving with a K&N decreases your gas mileage by quite a bit.
I can't give specific numbers, but when I had my K&N in my LS my mileage dropped about 80 miles per tank. Went from 320 (stock airbox) to 240 (K&N.)
The sound is great- yes...but in my case it actually took AWAY power (presented in my dyno test) and hurt my mileage.
There has to be another filter option beisdes K&N. Here's a link to my dyno results.
https://www.clublexus.com/forums/sho...threadid=63761
Originally posted by Invisibleman
I am getting really bad gas milage on my car for a while now. approximately 14mpg city. Dont know why though. I just changed the oil w/ full synthetic oil, changed spark plugs recently, and I added a K&N filter. Havent changed the O2 sensor yet but there is NO check engine light on. What could be the problem?
if this is all wrong, forgive me...i'm a newbie who drives an is300 5mt in Cali..
I have teh 1mz-fe engine in Toronto Canada.use my car alot on the highway and have a cold air intake and an exhaust (resonator back)i drive real hard( so i pin the gas all the time)
Have the usual synthtic oils for engine ,transmission and power steering( it also uses trans fluid)
plus bosch plat 4 plugs
i get 900 km if all highway
550-600 km if both
and 500 if all city
i don't use the a/c much unless summer
and i have 18 inch chrome rims
so i think i have really good mileage as part of the intake and exhaust mods aswhen i took it for emissions testing the tech who tested it at Lexus said he had never seen such low particle counts in any lexus ever
so i must have done something right.
Plus it really goes like stink now
thanks for reading my babble
550-600 km if both
and 500 if all city
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
I calculate it the old fashioned way.
Fill up at a pump, stop when the nozel shuts off itself and don't force fill the rest.
jot down mileage.
Drive until there is at most 1/4 of a tank left.
Fill up the same way at the same pump and nozel as before.
Divide the mileage by the amount pumped.
Drive off and have fun.
I am finding the calculated ave mpg displayed on my dash is actually very accurate.
sj
jot down mileage.
sj
