Gas mileage
#31
I mentioned this previously in this thread.
According to www.Lexus.com the PCV valve should be replaced at 60k or 90k depending on the inspection at that time. They didn't say definate. I also looked in the manual and it is not stated as routine service item, like filters and fluids.
From experience with GM, the aftermarket PCV I got at AutoZone ($3.98) was not up to vehicle/GM standards and ran rough. The $5.99 AC/Delco replacement part was a world of difference. Using experience as a guide for my logic, I would just pay the Lexus part man and get a genuine replacement for the PCV.
If it is not in the same place, it should look pretty much the same.
There is a thread that talks about the PCV on an LS and it is on the right side of the engine.
Incidently, I had a K&N filter in the stock air box on the Bonne. Each time the mileage dropped and the engine ran rough, it was the PCV. (but that was on a GM, "Garage Man's Companion")
#34
Well, Im back. Been driving the car for a week now. Filled up a whole tank with 93 gas. Drove all over town and also a trip to NYC and back to philly. Got 279 miles on 15.33 gallons. That works out to be 18.19 mpg. Its a little better than before. Im going to run another tank and see what happens, this time strictly city driving.
#35
18 is actually quite good gas mileage, unless you ran highway the entire time. if there was some rush hour stop-and-go, then that sounds about right. as long as you don't floor these cars too much, your mileage should be pretty good.
#36
Once you get the mpg stabilized or established, for curiosity sake, I would pop in a standard Lexus/Toyota air filter or aftermarket equivalent (Penzoil, STP, Fram, etc). Run it for 3 to four more tankfuls and see if that further increases your mpg into the low 20's.
this club is awesome
steviej
steviej
#37
So then I'm assuming that 20-21 mpg isn't so bad for a 122k mile ES? I do have the K&N as well... I can test the economy difference if anyone hasn't recently done so (in NY with the oxygenated gasoline for now).
Erik Quick
Erik Quick
#38
That's pretty decent if it is "around town driving". I would hope for a little higher if it was purely 55-75 mph straight out highway cruising.
I am not sure if I buy the K&N as a reason for low mileage.
My experience with K&N was a rectangular filter that was put in the stock air box of a '93 supercharged Bonneville. Similar to what would be done on the Lex unless you did a total air intake make-over. Didn't see a difference in mileage but picked up a few ponies.
That's why I asked him to try a stock filter to see. So far K&N doesn't list a filter for the 2002, so I can't try it on my own. It would be cool if you could do it, too. I'm a scientist by trade...the more data the better.
steviej
steviej
#39
Talk about pushing the Lex ('96 ES) to the max...
On my way up to Maine, I filled up about 17.5 gal-- one gallon shy of empty! -- after putting in 463 miles from the previous fill-up. That calculates to almost 26.5 MPG, probably the best fuel mileage I've gotten in a long while. Too bad the gas prices aren't being friendly these days...
#41
The '96 ES has an 18.5 gallon fuel tank, and yes, there is like a 2-3 gallon reserve when the orange (warning) light shows up. Still a sign of comfort for most of us
bowen.chau
RX - 1st Gen (1999-2003)
390
11-19-23 09:00 AM
