Cabin Air Filter/Engine Air Filter part #'s?
I need to order both filters for my '01 ES. Does anyone know the part numbers so I can begin my search?
Also, I read there are two side-by-side cabin air filters down near the pedals. So when I order a cabin air filter should I just order two?
FWIW, I've learned from experience that OEM (Part #: 17801-03010) is the best for engine filters, and is also the cheapest. It's around $18. For the cabin, it's the other way around. If you go with OE, it will cost you around $50. WIX is a good company for the cabin filter, and I got it through Amazon for roughly $20.
In fact, this is the exact one I bought. Wix 24895
Thank you for the part numbers. I've always had good luck with OEM filters in all our cars so I'm just going to stick with Toyota filters. I believe there are the appropriate ones:
http://lexus.sewellparts.com/accesso...2001/2521.html <- Engine Filter
http://lexus.sewellparts.com/accesso...2001/2454.html <- Cabin Filter
P.S. When you register with your CL username you get a sizable discount ($67 total down to $48)
LexusGuy01
11-14-20 11:17 AM
PCP20
04-26-08 10:11 AM
