DplanDman8 2001 ES Updates
#46
What do you mean JDM look? I have white Hids and white switch backs that turn to amber when I hit the turn signal then yellow fogs at the bottom. What do the JDM ones look like?
#48
I love the clear corners! Is that what you where talking about? For the JDM look? Where can you get those? I would also love some folding mirrors. Do you know where I cn get those too?
All the help with these things would be great.
#49
Ok well I had to change all four tires to a bigger set!
The 215/35 on the 18x9.5 where too much stretch for the rims and they would leak air slowly over a couple days and they all four would be flat in the morning and would be popped off the bead so I couldn't air them back up
So in turn I changed them to 215/40 which doesn't seem like a big difference but when u slam a car and stance it! That tire is a lot bigger so it rubs a little bit but not too bad and the bead sets a lot better and I put some black sticky stuff on it to help hold the bead!
So I think I might want to go a little lower
#52
#56
You should get one they are fun cars!
