2 or 4 Camshaft seals?
04-03-13, 08:10 PM
Planning to do timing belt, pulleys, tensioner, water pump, gasket, and crankshaft seal. I guess I should do the camshaft seals as well but not sure how many to order. Also, any other things I should order? Timing belt seal/gasket?
Thanks
2000 es300, 200,000 miles
04-03-13, 09:34 PM
04-03-13, 11:06 PM
Other things you could change:
Thermostat
Thermostat Gasket
Power Steering Belt
Alternator Belt
Spark Plugs
04-03-13, 11:12 PM
Thanks for the quick responses. In my original post...The last sentence...I meant to ask if I should get a new timing belt cover gasket?
04-04-13, 11:32 AM
Not needed if you're not leaking oil. I had a minor leak and the gasket was still good. Although I did have a replacement, so I switched it out.
04-04-13, 12:13 PM
Good time to drain the radiator, and get new coolant in the entire system. You will already be draining most of the engine block.
04-04-13, 01:25 PM
Quote:
Originally Posted by
hypervish
+1 on that. The engine block drain ***** are very easy to locate, as opposed to other cars.
99rx
RX - 1st Gen (1999-2003)
07-23-11 07:59 AM
handzilla
06-06-11 07:00 AM
milellie11
06-22-10 10:21 PM
LexusPhan
08-21-09 05:45 PM
daudi81
Performance & Maintenance
11-08-08 08:34 PM
