few quick questions on changing rear brake pads...
Hi,
I have a 99 ES300 and will be changing the rear brake pads and had a few quick questions:
1. Do you have to engage the parking brake when doing this job? (I don't think we need to or the caliper won't come off, correct?)
2. What is the torque amount for the caliper bolt once you go to tighten it?
3. What is the torque amount for the tire lug nut once you go to tighten it?
4. Is there any DIY tutorial for rear brake pads you know of?
Thanks!
Thanks!
If you are not replacing the rotors, no, you do not have to. The parking brake uses the inside shoes.
The smaller caliper bolt is 14 ftlb. The larger bolt is 34 ftlb.
80-100 ftlb
Most cars are the same. Do a google search.
80-100 ftlb
man8959
Suspension and Brakes
18
07-13-08 09:38 PM
disc108
Maintenance
01-21-03 09:56 PM
